I'm using SDK 12.1.0, gcc, nRF51822, no SD init'ed or enabled at the time this code is running. I need to retain the values of a bunch of variables across a sys off.
Here's my test variable:
static int8_t retained_ram_test_int __attribute__ ((section(".noinit")));
and test function:
printf("Retained RAM test.\n");
uint32_t gp_reg = NRF_POWER->GPREGRET;
bool started_from_test = (gp_reg == START_FROM_TEST);
NRF_POWER->GPREGRET = 0x00000000UL;
if (started_from_test)
printf("After sys off. Retained RAM value: %d.\n", retained_ram_test_int);
printf("Done. Did we see a value > 0?\n");
while (true)
__WFE();
printf("Before sys off. Writing to value in retained RAM.\n");
// Retain RAM. This is NOT the method used by the <SDK>/examples/peripheral/ram_retention application, it's one from this post:
// devzone.nordicsemi.com/.../
NRF_POWER->RAMON = POWER_RAMON_OFFRAM0_RAM0On << POWER_RAMON_OFFRAM0_Pos
| POWER_RAMON_OFFRAM1_RAM1On << POWER_RAMON_OFFRAM1_Pos
| POWER_RAMON_ONRAM0_RAM0On << POWER_RAMON_ONRAM0_Pos
| POWER_RAMON_ONRAM1_RAM1On << POWER_RAMON_ONRAM1_Pos;
NRF_POWER->RAMONB = POWER_RAMONB_OFFRAM2_RAM2On << POWER_RAMONB_OFFRAM2_Pos
| POWER_RAMONB_OFFRAM3_RAM3On << POWER_RAMONB_OFFRAM3_Pos
| POWER_RAMONB_ONRAM2_RAM2On << POWER_RAMONB_ONRAM2_Pos
| POWER_RAMONB_ONRAM3_RAM3On << POWER_RAMONB_ONRAM3_Pos;
retained_ram_test_int = 1;
// Wake on motion.
printf("Programming accelerometer for alerting phase 1.\n");
acc_kionix_init();
acc_kionix_program(KIONIX_MODE_ALERTING_PHASE_1);
acc_kionix_clear_interrupt(NULL, 0);
nrf_gpio_cfg_sense_input(PIN_KX_INT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_SENSE_HIGH);
printf("Going into sys off. Shake me to wake me, then continue in gdb.\n");
DEBUG_LED_OFF_ALL();
DEBUG_LED_ON(LED_SYSTEM_OFF);
nrf_delay_ms(100);
NRF_POWER->GPREGRET = START_FROM_TEST;
NRF_POWER->SYSTEMOFF = 1;
// Should be unreachable code:
while (true)
__WFE();
The acc_* functions are an accelerometer driver that just fires an interrupt to wake up the nRF51822.
Here's my linker script:
SEARCH_DIR(.)
GROUP(-lgcc -lc -lnosys)
MEMORY
FLASH (rx) : ORIGIN = 0x1B000, LENGTH = 0x21C00
RAM (rwx) : ORIGIN = 0x20002008, LENGTH = 0x5FF8
NOINIT (rwx) : ORIGIN = 0x20007F5C, LENGTH = 0xA4
BOOTLOADER_SETTINGS (rw) : ORIGIN = 0x0003FC00, LENGTH = 0x0400
UICR_BOOTLOADER (r) : ORIGIN = 0x10001014, LENGTH = 0x04
SECTIONS
.bootloaderSettings(NOLOAD) :
} > BOOTLOADER_SETTINGS
.uicrBootStartAddress :
KEEP(*(.uicrBootStartAddress))
} > UICR_BOOTLOADER
.noinit(NOLOAD) :
*(.noinit*)
} > NOINIT
SECTIONS
.fs_data :
PROVIDE(__start_fs_data = .);
KEEP(*(.fs_data))
PROVIDE(__stop_fs_data = .);
} > RAM
} INSERT AFTER .data;
INCLUDE "nrf51_common.ld"
I use the stock gcc_startup_nRF51.S
file from the SDK. The test fails. Output:
main()
Retained RAM test.
main()
Retained RAM test.
After sys off. Retained RAM value: 0.
I've read this:
When gdb breaks at the ResetHandler, it's not possible to read the value of retained_ram_test_int or step through the ResetHandler line by line. If I try to step, I end up on the first line of main(), by which time my variable is already 0.
