DFU issue on custom board
I am using a custom board and my setup looks like this:
  • nrf51 chip
  • 16KB RAM
  • 256KB of Flash
  • external crystal of 32MHz
  • SDK12.1
  • Compiling on Linux using GCC
I am trying to port the bootloader_secure example to the custom board. I have been able to run this example to the pca10028 board. Same code, some build system. Only with a few needed adjustments for the pca10028 of course. No issues currently.
Now, with the same build system I just compile this for the custom board. To make things more interesting, I am using the same linker script for both the pca10028 and the custom one - that is the adjusted one for the 16KB of RAM (remember the example runs OK on pca10028). This looks like this:
/* Linker script to configure memory regions. */
SEARCH_DIR(.)
GROUP(-lgcc -lc -lnosys)
MEMORY
  /** Flash start address for the bootloader. This setting will also be stored in UICR to allow the
   *  MBR to init the bootloader when starting the system. This value must correspond to
   *  BOOTLOADER_REGION_START found in dfu_types.h. The system is prevented from starting up if
   *  those values do not match. The check is performed in main.c, see
   *  APP_ERROR_CHECK_BOOL(*((uint32_t *)NRF_UICR_BOOT_START_ADDRESS) == BOOTLOADER_REGION_START);
  /*FLASH (rx) : ORIGIN = 0x35C00, LENGTH = 0xA000*/
  /** RAM Region for bootloader. This setting is suitable when used with s110, s120, s130, s310. */
  /* RAM (rwx) :  ORIGIN = 0x20002560, LENGTH = 0x1A20 */
  RAM (rwx) :  ORIGIN = 0x20002C00, LENGTH = 0x1380
  /** Location of non initialized RAM. Non initialized RAM is used for exchanging bond information
   *  from application to bootloader when using buttonluss DFU OTA.
  NOINIT (rwx) :  ORIGIN = 0x20003F80, LENGTH = 0x80
  /** Location of bootloader setting in at the last flash page. */
  BOOTLOADER_SETTINGS (rw) : ORIGIN = 0x0003FC00, LENGTH = 0x0400
  /** Location in UICR where bootloader start address is stored. */
  UICR_BOOTLOADER (r) : ORIGIN = 0x10001014, LENGTH = 0x04
SECTIONS
  /* Ensures the bootloader settings are placed at the last flash page. */
  .bootloaderSettings(NOLOAD) :
  } > BOOTLOADER_SETTINGS
  /* Ensures the Bootloader start address in flash is written to UICR when flashing the image. */
  .uicrBootStartAddress :
    KEEP(*(.uicrBootStartAddress))
  } > UICR_BOOTLOADER
  /* No init RAM section in bootloader. Used for bond information exchange. */
  .noinit(NOLOAD) :
  } > NOINIT
  /* other placements follow here... */
SECTIONS
  . = ALIGN(4);
  .fs_data :
    PROVIDE(__start_fs_data = .);
    KEEP(*(.fs_data))
    PROVIDE(__stop_fs_data = .);
  } > RAM
  . = ALIGN(4);
  .svc_data :
    PROVIDE(__start_svc_data = .);
    KEEP(*(.svc_data))
    PROVIDE(__stop_svc_data = .);
  } > RAM
  . = ALIGN(4);
  .dfu_trans :
    PROVIDE(__start_dfu_trans = .);
    KEEP(*(.dfu_trans))
    PROVIDE(__stop_dfu_trans = .);
  } > RAM
} INSERT AFTER .data
INCLUDE "nrf51_common.ld"
Stack size for both examples is at 255 bytes. Heap is zero.
This is the debug output of the custom board:
ain)		Inside main
(nrf_bootloader_init)		In nrf_bootloader_init
(nrf_dfu_init)		In real nrf_dfu_init
(nrf_dfu_settings_init)		running nrf_dfu_settings_init
(nrf_dfu_continue)		Enter nrf_dfu_continue
(nrf_dfu_continue_bank)		Single: Invalid bank
(nrf_dfu_app_is_valid)		Enter nrf_dfu_app_is_valid
(nrf_dfu_app_is_valid)		Return false in valid app check
(nrf_dfu_transports_init)		In nrf_dfu_transports_init
(nrf_dfu_transports_init)		num transports: 1
(ble_stack_init)		vector table: 0x00035C00
(softdevice_enable)		sd_ble_enable: RAM START at 0x20001FE8
(softdevice_enable)		sd_ble_enable: app_ram_base should be adjusted to 0x200025E0
(softdevice_enable)		ram size should be adjusted to 0x5A20
(nrf_dfu_transports_init)		After nrf_dfu_transports_init
(nrf_dfu_init)		Could not initalize DFU transport: 0x00F42400
ain)		Inside main
The program reaches a point where it resets itself. And this happens forever. The softdevice has no chance in getting into advertising mode.
Any clues? Any ideas how to move forward?
Thanks!
  • FormerMember
    0 FormerMember
    From the debug output, it looks like the problem is related to the amount of RAM allocated for the softdevice.
    Update 07.11.2016: The RAM settings for the 16 kB nRF51, optimization level 3 can set to the following:
    RAM start: 0x200025E0
    RAM size/length: 0x1A20
    04.11.2016: The output says:
    It means that the length of RAM in the linker file should be adjusted to at least 0x5A20:
    RAM (rwx) :  ORIGIN = 0x20002C00, LENGTH = 0x5A20
    Let me know if it still doesn't work after changing the size/length.
  • FormerMember
    0 FormerMember in reply to FormerMember
    I have updated the answer with proper values. Let me know if it doesn't work.
