Hi All,
I'm implementing system clock using approach similar to devzone.nordicsemi.com/.../
The idea:
NRF_RTC_EVENT_COMPARE_0 -> PPI -> NRF_TIMER_TASK_COUNT
(translate 125ms RTC ticks to counter mode TIMER 1sec ticks)
All works great, however handling UNIX timestamps require handling "overflows" to update global counter, because TIMER1...4 instances are 16bit max. (I'm using SoftDevice so TIMER0 is not available)
Handler for 8bit TIMER looks like this:
static void hwtimer_handler(nrf_timer_event_t event_type, void* p_context)
if (p_context == &m_hwtimer && event_type == NRF_TIMER_EVENT_COMPARE1)
m_epoch_time += 0x100UL;
And "real time" getter:
uint32_t cval = nrf_drv_timer_capture(&m_hwtimer, NRF_TIMER_CC_CHANNEL0);
nrf_drv_timer_clear(&m_hwtimer);
nrf_drv_timer_compare_int_disable(&m_hwtimer, NRF_TIMER_CC_CHANNEL1); // write access to m_epoch_time must be atomic
m_epoch_time += cval;
nrf_drv_timer_compare_int_enable(&m_hwtimer, NRF_TIMER_CC_CHANNEL1); // write access to m_epoch_time must be atomic
return m_epoch_time;
To prevent race conditions when modifying m_epoch_time I just disabling interrupts. Is it optimal approach? Are race interrupts pended of declined? It's important to know because each interrupt decline equals to +1 second lost in system clock. Maybe better to temporarily disable events passing via PPI ? Which way is more safe?
PS: ARM arch is new for me, so please tell me if my question is ARM generic rather than NRF specific.
Best, Alex
