Our code is 21k excluding soft-device,as per the example 15k should be the max size limit of code to update FOTA. Is it possible to make changes in DFU bootloader so that i can transfer FOTA?
Hi DMS,
What do you mean by " per the example 15k should be the max size limit of code to update FOTA". With 512kB flash chip, the max sixe of the application should be 356kB as shown here.
My code size is 21.6K, i want to transfer over air is it possible ? i am planning to alter FOTA example
Yes, it should be possible. Please give me more information on the SDK version, S132 version you are using.
Please go ahead and do DFU, you have 356kB flash size budget.
