"....\dfu_public_key.c(20): error: #35: #error directive: "Debug public key not valid for production. Please see github.com/NordicSemiconducto... to generate it.
i found answers for linux OS in devzone, i need it for windows
If you are just testing out the DFU examples, you can use the project found in the [board_name]_debug folder in the secure DFU bootloader example. This will add a define that lets you use the template key. If you are using DFU for production, you will have to generate your own private/public key pair and add the public key to dfu_public_key.c, as described here.
I used this kjur.github.io/.../sample-ecdsa.html to generate public key.
Did you get it working? You can use nrfutil to create the keys in the correct format. You are supposed to store the generated public key in a new dfu_public_key.c file that replaces the old "debug-file".
