add/remove GATT service or characts with bonded device
Hello, I asked a question after this old one : old one and I read other posts on the subject.
I wonder whether explained constraints may have changed or not since I am using SD130 2.0 - SDK11- nRF51422.
My point is that I want my GATT server to create some services only after some app level transaction has passed. For this purpose, I create a transaction service so that a bonded peripheral can play with. Then after the event has occured, I trigger the creation of another applicative Gatt service. ideally, I want all this to be visible only after bonding, that is done with a static passphrase.
My experience is that when my peripheral app () is bonded to a central (Android), If I update my app with new services or remove services and flash the peripheral, my central still sees the same set of services and chars. This is quite annoying. I assumed at first that this would be because the Gatt table would be static in flash within the soft device for a given bond. but then I tried to flash the softdevice itself and I discovered that my Android central still connected and discovered the old set of services. I guess that whatever, if my app changes while GATT table has not, it might crash quite soon when the peripheral wants to access some supervised data. So I have to reset the bond when I change my services set.
  • is it possible to do it without giving up the bond ? (I don't want to disturb user with this static key too often) I guess this is on the android side... but maybe this behavior is linked to some bonding parameter that is set on the peripheral GATT server.
  • I use device manager, would the behavior be different with peer manager ?
Thanks for your help
