Prescaling on ADC battery voltage measurement
I'm trying to measure a scaled down battery voltage level on an ADC pin. Given my resistor values the voltage on the pin should be about 0.279 times VBATT, to fit within 1.2V. It's a lithium ion battery that shouldn't go over about 4.1V or 4.2V.
Here's how my ADC pin is set up. Note the "NoPrescaling".
	NRF_ADC->CONFIG	= (ADC_CONFIG_EXTREFSEL_None << ADC_CONFIG_EXTREFSEL_Pos) // We don't have any external reference pins.
		| (ADC_CONFIG_PSEL_AnalogInput2 << ADC_CONFIG_PSEL_Pos) // Use analog input 2.
		| (ADC_CONFIG_REFSEL_VBG << ADC_CONFIG_REFSEL_Pos) // Use internal 1.2V bandgap voltage as reference for conversion.
		| (ADC_CONFIG_INPSEL_AnalogInputNoPrescaling << ADC_CONFIG_INPSEL_Pos) // No prescaling.
		| (ADC_CONFIG_RES_8bit << ADC_CONFIG_RES_Pos); // 8 bit resolution.
There's some discussion of the arithmetic to be done on the NRF_ADC->RESULT in this thread:
devzone.nordicsemi.com/.../what-s-wrong-with-measuring-lithium-battery-voltage
My question is, why is the code in that thread using an ADC_PRE_SCALING_COMPENSATION value when the ADC is set to no prescaling?
Multiplying by 4 would get me a value pretty close to what I'm measuring with a multimeter, as it happens.
