Setting SAADC Resolution
I'm working with the SAADC peripheral example and I'm trying to add some code to set the ADC resolution. I've tried doing this several different ways based on what I can find in examples/the API reference, but I keep getting errors. I'm using SDK12.1 and Eclipse Mars.
First method I've tried (I insert this code at the top of my file with the other definitions):
#define SAADC_CONFIG_RESOLUTION NRF_SAADC_RESOLUTION_10BIT Gives an error that "SAADC_CONFIG_RESOLUTION" is redefined.
Second method:
void saadc_init(void) { nrf_drv_saadc_config_t saadc_config; saadc_config.resolution = NRF_SAADC_RESOLUTION_10BIT; ...
This second way I tried to define the resolution gives an error that "saadc_config is set, but not used"
I'm new to C/my nordic board so I assume there's something I'm missing about the structure definition, but I can't figure out the error. Any tips would be great. Thanks!
