saadc reading error in BMD300
Hi, I programmed nRF52 DK with BLE_APP_UART_SAADC_TIMER_DRIVEN with AIN6 pin as input and is working correctly. But when I programmed the same code in BMD300 the adc count value is not coming as expected! It looks like an offset of 43-45 is coming always when the pin is left unconnected. The count returns a value of 110-114(whereas it is 1023 in nRF52DK) when connected to VDD. I've also tried reading the same pin by making all the surrounding pins low. But same result.
 #define SAADC_SAMPLES_IN_BUFFER         1
    #define SAADC_SAMPLE_RATE_DIVIDER				0x2000;
            ret_code_t err_code;
    				uint16_t adc_value;
    				uint8_t value[SAADC_SAMPLES_IN_BUFFER*2];
    				uint8_t bytes_to_send;
    				// set buffers
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
    				// print samples on hardware UART and parse data for BLE transmission
         //   printf("ADC event number: %d\r\n",(int)m_adc_evt_counter);
            for (int i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
          //      printf("%d\r\n", p_event->data.done.p_buffer[i]);
    						adc_value = (uint16_t)p_event->data.done.p_buffer[i];
    			//			value[i*2] = adc_value;
    			//			value[(i*2)+1] = adc_value >> 8;
    				adc_count_temp = adc_value;
 sprintf(value,"M=%d",adc_count_temp);                           // prints current voltage
	err_code = ble_nus_string_send(&m_nus, value, sizeof(value));
    	//			sprintf(value,"c=%d",adc_value);
    				 adc_flag=1;
    				// Send data over BLE via NUS service. Makes sure not to send more than 20 bytes.
    				if((SAADC_SAMPLES_IN_BUFFER*2) <= 20)
    						bytes_to_send = (SAADC_SAMPLES_IN_BUFFER*2);
    						bytes_to_send = 20;
    	//			err_code = ble_nus_string_send(&m_nus, value, 10);
            m_adc_evt_counter++;
void saadc_init(void)
    nrf_saadc_channel_config_t channel_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(6, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
I have made this change as well.
#define NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(PIN_P) \
    .resistor_p = NRF_SAADC_RESISTOR_DISABLED,         \
    .resistor_n = NRF_SAADC_RESISTOR_DISABLED,         \
    .gain       = NRF_SAADC_GAIN1_4,                   \
    .reference  = SAADC_CH_CONFIG_REFSEL_VDD1_4,        \
    .acq_time   = NRF_SAADC_ACQTIME_10US,              \
    .mode       = NRF_SAADC_MODE_SINGLE_ENDED,         \
    .pin_p      = (nrf_saadc_input_t)(PIN_P),          \
    .pin_n      = NRF_SAADC_INPUT_DISABLED             \
This is the main function
    uint32_t err_code;
    bool erase_bonds;
    // Initialize.
	nrf_gpio_cfg_output(9);
	nrf_gpio_cfg_output(10);
	nrf_gpio_cfg_output(12);
	nrf_gpio_cfg_output(13);
	nrf_gpio_pin_clear(9);
	nrf_gpio_pin_clear(10);
	nrf_gpio_pin_clear(12);
	nrf_gpio_pin_clear(13);
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    uart_init();
    gpio_init();
    ble_stack_init();
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
    saadc_sampling_event_init();
    saadc_init();
    printf("\r\nUART Start!\r\n");
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    uint8_t c[15];
    // Enter main loop.
    for (;;)
        power_manage();
In the hardware side nothing is connected to the pin and yes I am testing with AIN6 (P0.30) or Pin 11 of BMD300. Is the settings correct? Or am I missing something in the code?
