Hello again,
I'm working with the ble_app_hrs example application with DFU app support. I'm following the DFU procedure and I've reached the point where I actually start the DFU process. At this point the application starts the bootloader.
My question is: What happens at this point? This is what I understand so far:
- I write
0x01,0x04to the DFU Control Point. - The DFU forwards a
BLE_DFU_STARTevent to the dfu_app_handler. - The event type is checked in the handler. If it's
BLE_DFU_STARTit starts the bootloader.
After this, I have no idea what happens.
I have a few observations:
The
0x04I wrote to the Control Point is saved, but not used. See here:case OP_CODE_START_DFU: SEGGER_RTT_WriteString(0,"Received ctrl_pt: Start DFU\n"); ble_dfu_evt.ble_dfu_evt_type = BLE_DFU_START; if (p_ble_write_evt->len < PKT_START_DFU_PARAM_LEN) { SEGGER_RTT_WriteString(0,"Operation failed\n"); return ble_dfu_response_send(p_dfu, (ble_dfu_procedure_t) p_ble_write_evt->data[0], BLE_DFU_RESP_VAL_OPER_FAILED); } ble_dfu_evt.evt.ble_dfu_pkt_write.len = 1; ble_dfu_evt.evt.ble_dfu_pkt_write.p_data = &(p_ble_write_evt->data[1]); p_dfu->evt_handler(p_dfu, &ble_dfu_evt); break;
p_dfu->evt_handler is the function below:
void dfu_app_on_dfu_evt(ble_dfu_t * p_dfu, ble_dfu_evt_t * p_evt)
switch (p_evt->ble_dfu_evt_type)
case BLE_DFU_START:
// Starting the bootloader - will cause reset.
bootloader_start(p_dfu->conn_handle);
// Unsupported event received from DFU Service.
// Send back BLE_DFU_RESP_VAL_NOT_SUPPORTED message to peer.
uint32_t err_code = ble_dfu_response_send(p_dfu,
BLE_DFU_START_PROCEDURE,
BLE_DFU_RESP_VAL_NOT_SUPPORTED);
As you can see, there's is no use whatsoever of ble_dfu_evt.evt.ble_dfu_pkt_write.p_data.
- How does the bootloader handle everything related to the BLE DFU Service?
- According to the documentation, after switching to DFU/Bootloader mode, I should reconnect and continue with normal DFU update. Does this include rediscovering services and characteristics, writing to CCCD and sending the
0x01,0x04that I already sent? (I'm not using shared bonding just yet).
Thank you in advance for your support in this lengthy post :)
