DFU not jumping to Application
I have a DFU issue. Using Visual GDB IDE and gcc tool chain.
I Can get my signed application generated into zip then DFU it into the device which all works. Once I get that far I expect it to jump to the application. It passes CRC etc then goes to jump but the application will not start. The address it uses is MAIN_APPLICATION_START_ADDR is = 0x1F000 nrf_bootloader_app_start(MAIN_APPLICATION_START_ADDR);
Without the DFU I know that my application starts so it is compatible with the softdevice. Is there something I need to add to my make file? In my application It has placed the ISR_Vector at 0x1f000 which I think should be correct for the DFU.
Thank you
