Hello everyone,
I am trying to use Segger Embedded Studio for a simple explerimental project. I started from the sample FDS example from github and build something on it. Now I create some file/records and try to remove them.
I followed the instructions from the post on the UNPLACED sections from there : devzone.nordicsemi.com/.../
It does run but I still have an issue.
I have a warning while SES generates the linker file:
cannot place section .stack at end of segment because section .fs_data_run does not have a fixed size
I did not payed attention until my code tried to delete a record from the NVM and went systematically into Hardfault.
So I simply tried to add a size to the .fs_data_run section declaration in the xml file:
<MemorySegment name="$(FLASH_NAME:FLASH)">
<ProgramSection alignment="4" load="Yes" runin=".fs_data_run" name=".fs_data" />
</MemorySegment>
<MemorySegment name="$(RAM_NAME:RAM);SRAM">
<ProgramSection alignment="4" size="3072" load="No" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
</MemorySegment>
This made the warning disappear, however it did not took away the hardfault I encounter.
According to what SES show while running step by step code, this hardfault happens exactly in the fds.c functionrecord_find_and_delete
, at the moment the page is marked as ready for garbage collection even though the m_pages
variable looks OK and is accessible to watch:
if (record_find_by_desc(&desc, &page))
// Flag the record as dirty.
ret = record_header_flag_dirty((uint32_t*)desc.p_record);
// This page can now be garbage collected.
m_pages[page].can_gc = true; // **<<<<----------- HARDFAULT**
I cannot really say why this is happening. However I feel like it is really connected because if I build the exact same project using gcc it is working fine and I don't encounter any hardfault.
Did anyone encounter the same issue? Hopefully resolved it?
Thank you for your help!
[EDIT] Some of my parameters, if that could help: in sdk_config.h
#define FDS_ENABLED 1
#define FDS_OP_QUEUE_SIZE 4
#define FDS_CHUNK_QUEUE_SIZE 8
#define FDS_MAX_USERS 8
#define FDS_VIRTUAL_PAGES 3
#define FDS_VIRTUAL_PAGE_SIZE 1024
#define FSTORAGE_ENABLED 1
#define FS_QUEUE_SIZE 4
#define FS_OP_MAX_RETRIES 3
#define FS_MAX_WRITE_SIZE_WORDS 1024
And as macros in SES:
FLASH_START=0x1F000
SRAM_START=0x20002128
FLASH_SIZE=0x61000
SRAM_SIZE=0xded8
