PTS: List of prequalified layers or tests
Hello.
Now I'm using nRF51422 and SoftDevice S310. And I'm trying to pass Bluetooth Consistency Check and PTS.
I read this question and answer.
devzone.nordicsemi.com/.../
if SoftDevice had been tested in advance, I think no need to test PTS again. So I want to know which Layer and which tests are already qualified. If you know, would you tell me the documents which I refer?
  • You are right, since the softdevice is already qualified you don't have to requalify. In fact it's not possible for you to requalify this as you don't have access to the controll interface to do so. Please look at the End product listing to see which tests are qualified. I think you can event reference the qualified design or the component qdid in the test plan generator to see what tests are performed.
    i have a pretty similar question. I don't use directly a nrf51 but inside of a module it is a nrf51822 with SD130 v2.0.0
    Do I have to reference to the modul or can I reference to the nrf51 SD130 V2.0.0 (QDID: 80592) or should i reference both?
    I would prefer the nrf51 QDID because at the moduls ICS there are less features tested.
    Thanks in advice.
  • I think the module manufacturers usually prefer that you reference their QDID. However you could reference our as well, but if you do you should do an reassessment on whether you need to redo rf-phy. Another option would be to combine our qualified design with the rf-phy from the module manufacturer.
