Seeking a setup for tuning the antenna for nRF51422
In short:Is it feasible to use RSSI values when tuning the antenna?
I have a custom board with an nRF51422 on which I have designed the RF part to be as much as possibly according to the development kit. I have however been obliged to change the antenna and board thickness due to space issues. So I need to adjust the antenna to obtain good matching.
I see two options: [b]1) Have nRF51422 broadcast packets and measure the RSSI in the receiver (for instance nRF2779 USB dongle - which is part of eval. and dev. kits) 2) Have nRF2779 USB dongle broadcast packets and measure the RSSI in nRF51422 from the RSSISAMPLE register. [/b]
The RSSI will in both cases be a measure of the antenna matching properties and can thus be used to find the best (not necessarily optimum) antenna length.
Both options suffer that I did not find any examples on how to read the RSSI value. Search on thisisant.com indicate that option 1) require a CC257X device when using the ANT_RSSI_Demo from thisisant.com
So I seek an example on how to read the RSSI value from either nRF51422 or nRF2779 USB dongle.
I am aware of the method described in the excellent white paper by Nordic SemiconductornWP-017 on antenna matching using Smith chart and a VNA. This is very comprehensive and require an VNA. I was wondering to use something simpler at least for a start.
On thisisant.com there is an Windows appication: ANT_RSSI_Demo which supposedly can display RSSI values, but it does not work on nRF2779 USB dongle. The error message indicates that it is requiring a CC257x chip-set device. It is a bit unclear where to get such with USB interface.
Any suggestions on practical antenna tuning are welcome. Thanks
