How to create a nRF8001 configuration for touch device with nRFgo
According to Microsoft's instruction on HID touch device, msdn.microsoft.com/.../dn672271(v=vs.85).aspx, a HID touch device should create a report (descriptor) as below,
0x05, 0x0d,                         // USAGE_PAGE (Digitizers)
0x09, 0x04,                         // USAGE (Touch Screen)
0xa1, 0x01,                         // COLLECTION (Application)
0x85, 0x01,                        //   REPORT_ID (Touch)
0x09, 0x22,                         //   USAGE (Finger)
0xa1, 0x02,                         //     COLLECTION (Logical)
0x09, 0x42,                         //       USAGE (Tip Switch)
0x15, 0x00,                         //       LOGICAL_MINIMUM (0)
0x25, 0x01,                         //       LOGICAL_MAXIMUM (1)
0x75, 0x01,                         //       REPORT_SIZE (1)
0x95, 0x01,                         //       REPORT_COUNT (1)
0x81, 0x02,                         //       INPUT (Data,Var,Abs)
0x95, 0x07,                         //       REPORT_COUNT (7)
0x81, 0x03,                         //       INPUT (Cnst,Ary,Abs)
0x75, 0x08,                         //       REPORT_SIZE (8)
0x09, 0x51,                         //       USAGE (Contact Identifier)
0x05, 0x01,                         //       USAGE_PAGE (Generic Desk..
0x26, 0xff, 0x0f,                   //       LOGICAL_MAXIMUM (4095)
0x75, 0x10,                         //       REPORT_SIZE (16)
0x55, 0x0e,                         //       UNIT_EXPONENT (-2)
0x65, 0x13,                         //       UNIT(Inch,EngLinear)
0x09, 0x30,                         //       USAGE (X)
0x35, 0x00,                         //       PHYSICAL_MINIMUM (0)
0x46, 0xb5, 0x04,                   //       PHYSICAL_MAXIMUM (1205)
0x95, 0x02,                         //       REPORT_COUNT (2)
0x46, 0x8a, 0x03,                   //       PHYSICAL_MAXIMUM (906)
0x09, 0x31,                         //       USAGE (Y)
0x09, 0x48,                         //       USAGE (Width)
0x09, 0x49,                         //       USAGE (Height)
0x55, 0x0C,                         //       UNIT_EXPONENT (-4)
0x65, 0x12,                         //       UNIT (Radians,SIROtation)
0x47, 0x6f, 0xf5, 0x00, 0x00,        //      PHYSICAL_MAXIMUM (62831)
0x27, 0x6f, 0xf5, 0x00, 0x00,       //       LOGICAL_MAXIMUM (62831)
0x09, 0x3f,                         //       USAGE (Azimuth[Orientation])
0xc0,                               //    END_COLLECTION
0x66, 0x01, 0x10,                   //     UNIT (Seconds)
0x47, 0xff, 0xff, 0x00, 0x00,      //       PHYSICAL_MAXIMUM (65535)
0x27, 0xff, 0xff, 0x00, 0x00,         //   LOGICAL_MAXIMUM (65535)
0x09, 0x56,                         //   USAGE (Scan Time)
0x09, 0x54,                         //   USAGE (Contact count)
0x25, 0x7f,                           //   LOGICAL_MAXIMUM (127)
0x85, REPORTID_MAX_COUNT,            //   REPORT_ID (Feature)
0x09, 0x55,                         //   USAGE(Contact Count Maximum)
0x25, 0x02,                         //   LOGICAL_MAXIMUM (2)
0xb1, 0x02,                         //   FEATURE (Data,Var,Abs)
0x85, 0x44,                      //   REPORT_ID (Feature)
0x06, 0x00, 0xff,                   //   USAGE_PAGE (Vendor Defined)
0x09, 0xC5,                         //   USAGE (Vendor Usage 0xC5)
0x26, 0xff, 0x00,                   //   LOGICAL_MAXIMUM (0xff)
0x96, 0x00,  0x01,                  //   REPORT_COUNT (0x100 (256))
0xc0,                               // END_COLLECTIONÂ  Â Â
How can I create a nRF8001 configuration with nRFgo which meets the above requirements? I tried days but still could not get it right. Please help! Thanks!
  • I have figured it out. Take the hid_template Joystick example for comparison.
    0x05, 0x01,                    // USAGE_PAGE (Generic Desktop)
    0x09, 0x04,                    // USAGE (Joystick)
    0x85, 0x01,                    //   REPORT_ID (1)
    0x09, 0x32,                    //     USAGE (Z)
    0x26, 0xff, 0x00,              //     LOGICAL_MAXIMUM (255)
    0x46, 0xff, 0x00,              //     PHYSICAL_MAXIMUM (255)
    0x95, 0x03,                    //     REPORT_COUNT (3)
    0x85, 0x02,                    // REPORT_ID (2)
    0x05, 0x09,                    //     USAGE_PAGE (Button)
    0x29, 0x02,                    //     USAGE_MAXIMUM (Button 2)
    0x19, 0x01,                    //     USAGE_MINIMUM (Button 1)
    0x81, 0x02,                    //     Input (Data, Variable, Absolute)
    0x95, 0x01,                    //     Report Count (1)
    0x75, 0x06,                    //     Report Size (6)
    0x81, 0x01,                    //     Input (Constant) for padding
    0xc0                           // END_COLLECTION
    There is a REPORT_ID (1) & (2), so the reference ID is 0101 (01 - Report ID, 01 - Type = Input). And in the hid_keyboard template, there is no Report ID, so the reference ID is 0001.
    Regarding the corresponding data, the hid_template for Joystick looks more clear. The first report (ID1) contains 3 bytes data, described in the Usagez as Z, Y, X, each for one byte with physical range 0~255 and mapping to logical range 0~255. The second report (ID2) contains 2 bits data for button 1 & 2 which represents the button on/off state. And there are 6 bits padding bits.
    I think I can now construct the digitizer configuration as listed in my question.
    Thanks for all the help!
