Calculate Memory Settings for 51822_xxAB and S130 V2.0.1
My Chip is a Insight SIP ISP1302. It's based on a 51822_xxAB, 128kb Flash and 16kb RAM.
I try to use the S130 with the UART Application.
The S130 2.0.1 requiers 108kb (1B000) Flash and 4.95kb (13C8) RAM.
When i calculate the Settings for Keil, i get the following values: ROM Start 1B000, Size 5000 RAM Start 13C8, Size 2C38
But it doesen't works.
In different Posts i see Values for the RAM Start of 20002000 or similar. What is that???
Can someone give me the correct values for my Project and explain how to calculate.
Thanks a lot!
  • AFIK.The SD needs more RAM if you use any features in the SD
    The beacon App settings are RAM Start 0x20001870 i.e SD takes 0x1870
    The UART example, which has a service is RAM Start 0x20001fe8
    The same value is used for the App Template and HRS etc etc, which all have a service.
  • Hi Cavemanatwork,,
    @rogerclark is correct, the RAM usage of the SoftDevice will depend on which the configuration the SoftDevice uses, e.g. the number of concurrent central links and peripheral links.
    The sd_ble_enable function takes app_ram_base as an argument and and on return this will contain the minimum start address of the application RAM region required by the SoftDevice for this configuration. Calling sd_ble_enable() with *p_app_ram_base set to 0 can be used during development to find out how much memory a specific configuration will need.
    Best regards
    Bjørn
