FW doesn't run after being flashed with Crossworks
I'm currently using CrossStudio as IDE. I've no problem in compiling and downloading the application in the nRF52832 microcontroller. However the application wouldn't start automatically after a download. Only if I disconnect the debugger from CrossStudio and power cycle the board, then the application run smoothly. A similar thing happens while debugging. If I make the debugger executing all the BLE initialisation code by running in one go to a code line placed after all the initialisation, the application has no problem and I can debug it step by step. Instead, If I step through the softdevice initialisation code, after a while I get a softdevice assert and the fault handler gets executed.
Any idea why this is happening?
Thanks
