I have a working project where I use PWM driver with LEDs on the development board. I make use of the d52_starterkit.h where I have the following definitions:
#define LED_A 24 //LED A on D52 Starter Kit IO Board
#define LED_B 31 //LED B on D52 Starter Kit IO Board
#define LED_C 17 //LED C on D52 Starter Kit IO Board
#define LED_D 20 //LED D on D52 Starter Kit IO Board
and
#define BSP_LED_0 LED_A
#define BSP_LED_1 LED_B
#define BSP_LED_2 LED_C
#define BSP_LED_3 LED_D
#define BSP_LED_0_MASK (1UL<<BSP_LED_0)
#define BSP_LED_1_MASK (1UL<<BSP_LED_1)
#define BSP_LED_2_MASK (1UL<<BSP_LED_2)
#define BSP_LED_3_MASK (1UL<<BSP_LED_3)
It's working fine with the correct LEDs when I start the PWM module like:
nrf_drv_pwm_config_t const nrf_drv_pwm_config =
.output_pins =
BSP_LED_2 | NRF_DRV_PWM_PIN_INVERTED, // channel 0
NRF_DRV_PWM_PIN_NOT_USED, // channel 1
BSP_LED_3 | NRF_DRV_PWM_PIN_INVERTED, // channel 2
NRF_DRV_PWM_PIN_NOT_USED // channel 3
My question is: why the LED pins here are 24, 31, 17 and 20 instead of 17, 18, 19 and 20 according to the DK documentation (P0.17, P0.18, P0.19 and P0.20)?
