nRF51822 problem restoring the demo app
Hello all,
I have nRF51822 and after one attempt to use it as a sniffer I have erase the demo app or everything else on it. Since then I was unable to turn back as it as it was. Also, after this the nRF UART android app is unable to discover the device.
So my question is - What should be done so I can restore the device like it was ( at least discoverable by nRF UART android app)?
Thanks in advance.
  • Doing an erase all, flashing a new softdevice and then flashing the application firmware should be sufficient to get any application running again.
    Have you tried running the debugger, to see exactly what's failing when things doesn't work?
  • Thanks Ole,
    I just had done this and everything is fine now.
    Thanks again for your reply.
  • No problem, but if you found my reply helpful, I'd appreciate it if you could click the "Accept as answer" button below it, to clear up this question.
    Also, thank-you like this isn't really necessary, and it's better to just upvote answers you like! :-)
