Problem with Notify (Custom and Standard Services)
i took the example in AN36 (with the led but deleted the button stuff) and added the Battery Level service. Both are working fine together. On top of that I took the battery service and coustomized it like shown in the files attached. I added this coustomized service twice to my project (first is called temperature and identical second one is called speed). The init of both looks like to following (just with diffrent names):
/**@brief Function for initializing Temperature Service.
static void temperature_init(void)
    uint32_t       err_code;
    ble_temperature_init_t temperature_init;
    memset(&temperature_init, 0, sizeof(temperature_init));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&temperature_init.temperature_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&temperature_init.temperature_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&temperature_init.temperature_attr_md.write_perm);
    temperature_init.evt_handler          = NULL;
    temperature_init.support_notification = true;
    err_code = ble_temperature_init(&m_temperature, &temperature_init);
And the services are init like following:
		speed_init();
		temperature_init();
		bas_init();
		lbs_init();
The UUIDs of both are different ofcourse. So when I use for example the iOS App like LightBlue but notify works only for the temperature service not for speed. Can someone help me with this issue? Does it have something with the copied services to do? Or is there a limitation on services with notification?
(BTW: bas notify also works fine)
ble_temperature.c
ble_temperature.h
