Undefined references in NFC
Having just got the DFU functionality working I got the task of trying to add NFC functionality to the application. The code side was not a problem since I got a c and h file that should work belonging to a similar project (but different device) from workmate.
However, there are problems. The NFC code needs some functions (nfc_t2t_setup, nfc_t2t_payload_set and nfc_t2t_emulation_start) that are apparently in the relevant library (in this case nfc_t2t_lib_gcc.a). At least nm lists these functions in the library file. Though it seems odd to me that the gcc library over 20 times as large in size as the keil library).
However, if I try to build the project the linker complains that these symbols are missing even though I have added the library to makefile. What might be the problem ? It is also complaining about some redefinitions (e.g. SystemCoreClockUpdate, SystemInit and __StackTop). These definitions are in the common linker memory settings file. Why should these definitions even be in the nfc library anyway ?
