ADC issue (strange things happen when measuring)
i am using the adc module to read 3 channels in an app_timer handler. I configure the adc each time i get into the handler to read the desired input and read it twice (first a dummy read out). I am using the pca10005 board. My issue is that no matter which analog input pin is use (currently AIN2,3 and 4) i get 0x03FF read at everyone of them. Like for example:
  • i use pin AIN2 and connect it to 3V3
  • all others are connected to e.g. GND or floating (result is the same no matter where the others are connected to)
  • my handler measures at all pins ( AIN2,3 and 4) the 3V3 (0x03FF) connected just to AIN2
My system voltage is 3.3V and my max ADC input voltage is 3.3V. The configuration in my app_timer handle function is like following:
static void meas_timeout_handler(void * p_context)
    //uint32_t        err_code;
		static uint8_t channel = 0;
		uint32_t adcChannelRawValue = 0;
		uint32_t adcChannelMeasuredVoltage = 0;
		UNUSED_PARAMETER(p_context);
    NRF_ADC->CONFIG = (ADC_CONFIG_RES_10bit << ADC_CONFIG_RES_Pos) |
											(ADC_CONFIG_INPSEL_AnalogInputOneThirdPrescaling << ADC_CONFIG_INPSEL_Pos) |
                      (ADC_CONFIG_REFSEL_VBG << ADC_CONFIG_REFSEL_Pos) |
                      (ADC_CONFIG_EXTREFSEL_None << ADC_CONFIG_EXTREFSEL_Pos);
		if(channel > 2)
				channel = 0;
		switch(channel)
			case BATTERY_VOLTAGE_SENSOR: NRF_ADC->CONFIG |= (ADC_CONFIG_PSEL_AnalogInput2 << ADC_CONFIG_PSEL_Pos);
			case BATTERY_CURRENT_SENSOR: NRF_ADC->CONFIG |= (ADC_CONFIG_PSEL_AnalogInput3 << ADC_CONFIG_PSEL_Pos);
			case LED_TEMPERATURE_SENSOR: NRF_ADC->CONFIG |= (ADC_CONFIG_PSEL_AnalogInput4 << ADC_CONFIG_PSEL_Pos);
						// Start the ADC and dummy read
						NRF_ADC->EVENTS_END  = 0;
						NRF_ADC->TASKS_START = 1;
						while(!NRF_ADC->EVENTS_END);
						adcChannelRawValue = NRF_ADC->RESULT;
						NRF_ADC->TASKS_STOP = 1;
		// Start the ADC
		adcChannelMeasuredVoltage = adcChannelRawValue;
		//adcChannelMeasuredVoltage = (adcChannelRawValue * 3 * VBG_VOLTAGE_IN_MV) / ADC_RANGE_10BIT;
		switch(channel)
						deviceSensorValue[BATTERY_VOLTAGE_SENSOR] = adcChannelMeasuredVoltage;
						battery_level_update();
						m_lis_info.value_current_battery = (uint16_t)adcChannelMeasuredVoltage;
						status_informations_update();
						m_lis_info.value_temp_led = (uint16_t)adcChannelMeasuredVoltage;
			case CHIP_TEMPERATURE_SENSOR:
						m_lis_info.value_temp_chip = (uint16_t)deviceSensorValue[CHIP_TEMPERATURE_SENSOR];
		channel++;
                //zero all vars passed to status_informations_update() to see described issue more clearly
		m_lis_info.value_current_battery = 0;
		m_lis_info.value_temp_led =	0;
		m_lis_info.value_temp_chip = 0;
Can anyone help me? I think my adc is configurated the right way. Is there a issue reading the adc?
Kind regards
