want to send a float as a value of a characteristic
I have successfully achieved this using the simple way
Below is the example of just two float variables in an array.
float temperature[2]= {1.1,2.2};
attr_char_value.init_len = 8;
attr_char_value.init_offs = 0;
attr_char_value.max_len = 8;
attr_char_value.p_value = (uint8_t*)&temperature;
And this works fine, in the future I want to be able to send180 variables so i will need to change
attr_char_value.max_len = 180;
While reading up upon Heart monitor and Blood pressure monitoring services, they use this method:
static uint8_t hts_measurement_encode(ble_hts_t * p_hts,
ble_hts_meas_t * p_hts_meas,
uint8_t * p_encoded_buffer)
uint8_t flags = 0;
uint8_t len = 1;
uint32_t encoded_temp;
// Flags field
if (p_hts_meas->temp_in_fahr_units)
flags |= HTS_MEAS_FLAG_TEMP_UNITS_BIT;
if (p_hts_meas->time_stamp_present)
flags |= HTS_MEAS_FLAG_TIME_STAMP_BIT;
// Temperature Measurement Value field
encoded_temp = ((p_hts_meas->temp_in_fahr.exponent << 24) & 0xFF000000) |
((p_hts_meas->temp_in_fahr.mantissa << 0) & 0x00FFFFFF);
encoded_temp = ((p_hts_meas->temp_in_celcius.exponent << 24) & 0xFF000000) |
((p_hts_meas->temp_in_celcius.mantissa << 0) & 0x00FFFFFF);
len += uint32_encode(encoded_temp, &p_encoded_buffer[len]);
// Time Stamp field
len += ble_date_time_encode(&p_hts_meas->time_stamp, &p_encoded_buffer[len]);
// Temperature Type field
if (p_hts_meas->temp_type_present)
flags |= HTS_MEAS_FLAG_TEMP_TYPE_BIT;
p_encoded_buffer[len++] = p_hts_meas->temp_type;
// Flags field
p_encoded_buffer[0] = flags;
return len;
This code uses a struct called
typedef struct
int8_t exponent; /**< Base 10 exponent */
int32_t mantissa; /**< Mantissa, should be using only 24 bits */
} ieee_float32_t;
So my question is, is this another way or better way of sending a float variable?? I don't understand what they are doing here as almost every NRF ble example uses this method.
