micro-ecc installation/bootloader make problem
I'm making bootloader(nrf51822xxAA SDK12.1.0 and SD130 version). I have some problem in micro-ecc installation.
To install micro-ecc, complete the following steps: 1.Install version 4.9-2015-q3-update of the GCC compiler toolchain for ARM. You can use ARM's Launchpad to find the toolchain for your operating system. --> I installed same version into C:\Program Files (x86)\GNU Tools ARM Embedded folder.
2.Make sure that make is installed (see, for example, MinGW, GNU Make, or Xcode). --> I installed GNU Make 3.81 version into C:\Program Files (x86)\GnuWin32
3.Clone the micro-ecc GitHub repository into InstallFolder\external\micro-ecc\micro-ecc. --> I cloned like above.
4.Enter the subdirectory for the SoC and the toolchain that you are using to build your application: ◦InstallFolder\external\micro-ecc\nrf51_keil\armgcc --> I don't know how should I do. I don't understand well.
5.Run make to compile the micro-ecc library. --> I don't know how should I do. I don't understand well.
Additionally, I don't know how should I arrange the IRA1 area. I'm using below area.
                   IROM1 START/SIZE  ||  IRAM1 START/SIZE
application 0x1B000/0x25000 || 0x20001FE8/0x2018 bootloader 0x3AC00/0x5000 || ?/?
It's difficult to understand all in shot period because of my 1st Nordic use.
Thanks.
