Bonding only when client is close to server?
What's the proper way to implement bonding that depends on proximity (rather than a whitelist)? So when the client (phone) is close (say, five to ten centimeters) to the server (BTLE peripheral) then there is a bond created and the devices can now communicate over a larger range. I'm looking at the proximity example, but if there are other resources out there, please point them to me if possible. Thanks!
  • There isn't really any way to automatically do this, and the exact method used would depend on your use case.
    If your application has some way of entering a bonding mode, it could be possible to reduce the output power, and possibly also check the RSSI of incoming packets and disconnect if it's too low in this mode. RSSI monitoring can be enabled when in a connection with sd_ble_gap_rssi() start.
  • To clean things up, I'd be happy if you could evaluate the answer you have received and accept it if you feel it's sufficient. If not, it might be useful to expand your question a little and provide further information.
  • Hello @bad time simulator
    You can approximate this behavior using RSSI, but BLE doesn't provide a reliable way to enforce an exact distance of 5–10 cm.
    One approach is to advertise at reduced TX power and monitor RSSI after the connection is established. In the nRF5 SDK, you can use sd_ble_gap_rssi_start() to monitor the signal strength and only initiate bonding when the RSSI stays above a chosen threshold for several consecutive measurements.
    However, RSSI varies with phone models, antenna orientation, and the surrounding environment, so you'll need to calibrate the threshold and use some hysteresis to avoid unstable behavior.
    If you need to guarantee that the devices are physically close before bonding, NFC-based out-of-band pairing would be a more reliable solution than RSSI alone.
