fds_record_write doesn't trigger a FDS_EVT_WRITE event
My problem is pretty much identical to this one:
devzone.nordicsemi.com/.../
My functions look exactly like the ones posted in the original question and I was indeed making the same mistake that was being made in that case. But after I applied the fix, and added the fs_sys_evt_handler to my softdevice callback, I still did not receive any flash events. I have even tried copy pasting most of the code from the original question, but that hasn't worked either.
I am using an nRF51 board with the s130 softdevice and the v12.1.0 SDK. Any help would be appreciated!
Thank you.
Regards, Sid
  • I'll run that hex file today and let you know if it worked.
    Below are my config settings to do with FDS:
    #define FDS_ENABLED 1
    #if (FDS_ENABLED == 1)
    #   define FDS_OP_QUEUE_SIZE        4
    #   define FDS_CHUNK_QUEUE_SIZE     8
    #   define FDS_MAX_USERS            8
    #   define FDS_VIRTUAL_PAGES        3
    #if (NRF52 == 1)
    #   define FDS_VIRTUAL_PAGE_SIZE    1024
    #else
    #   define FDS_VIRTUAL_PAGE_SIZE    256
    #endif // </e>
    #define FSTORAGE_ENABLED 1
    #if (FSTORAGE_ENABLED == 1)
    #   define FS_QUEUE_SIZE            4
    #   define FS_OP_MAX_RETRIES        3
    #   define FS_MAX_WRITE_SIZE_WORDS  256
    #endif // </e>
    Thanks!
    #if (NRF52 == 1)
    #else
    #endif // </e>
    #endif // </e>
    Thanks!
