Timer with two compared values
Hello all,
I try to trigger two events with two different periods, the first at 200ms, the second at 300ms. When I set the same period for the compared value, it works correctly, but when I set differents periods (respectively 200 and 300 ms) it didn't work. Bellow my code :
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is property of Nordic Semiconductor ASA.
 * Terms and conditions of usage are described in detail in NORDIC
 * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
 * Licensees are granted free, non-transferable use of the information. NO
 * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
 * the file.
/** @file
* @defgroup gpiote_example_main main.c
* @ingroup nrf_gpiote_example
* @brief GPIOTE Example Application main file.
* This file contains the source code for a sample application using GPIOTE.
#include <stdbool.h>
#include <stdint.h>
#include "nrf.h"
#include "nrf_gpiote.h"
#include "nrf_gpio.h"
#include "boards.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "nrf_drv_gpiote.h"
#include "app_error.h"
#ifdef BSP_LED_0
    #define GPIO_OUTPUT_PIN_NUMBER BSP_LED_0  /**< Pin number for output. */
#ifndef GPIO_OUTPUT_PIN_NUMBER
    #error "Please indicate output pin"
#define PERIOD_0 200
#define PERIOD_1 300
static nrf_drv_timer_t timer = NRF_DRV_TIMER_INSTANCE(0);
void timer_dummy_handler(nrf_timer_event_t event_type, void * p_context)
      uint32_t compare_evt_addr_0, compare_evt_addr_1;
      uint32_t gpiote_task_addr_0, gpiote_task_addr_1;
      nrf_ppi_channel_t ppi_channel_0, ppi_channel_1;
      ret_code_t err_code;
      err_code = nrf_drv_ppi_channel_alloc(&ppi_channel_0);
      err_code = nrf_drv_ppi_channel_alloc(&ppi_channel_1);
      compare_evt_addr_0 = nrf_drv_timer_event_address_get(&timer, NRF_TIMER_EVENT_COMPARE0);
      gpiote_task_addr_0 = nrf_drv_gpiote_out_task_addr_get(BSP_LED_0);
      compare_evt_addr_1 = nrf_drv_timer_event_address_get(&timer, NRF_TIMER_EVENT_COMPARE1);
      gpiote_task_addr_1 = nrf_drv_gpiote_out_task_addr_get(BSP_LED_1);
      err_code = nrf_drv_ppi_channel_enable(ppi_channel_0);
      err_code = nrf_drv_ppi_channel_enable(ppi_channel_1);
switch (event_type)
        case NRF_TIMER_EVENT_COMPARE0:
        err_code = nrf_drv_ppi_channel_assign(ppi_channel_0, compare_evt_addr_0, gpiote_task_addr_0);
        case NRF_TIMER_EVENT_COMPARE1:
          err_code = nrf_drv_ppi_channel_assign(ppi_channel_1, compare_evt_addr_1, gpiote_task_addr_1);
static void led_blinking_setup()
    nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
    err_code = nrf_drv_gpiote_out_init(BSP_LED_0, &config);
    err_code = nrf_drv_gpiote_out_init(BSP_LED_1, &config);
    nrf_drv_timer_extended_compare(&timer, (nrf_timer_cc_channel_t)0, PERIOD_0 * 1000UL, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    nrf_drv_timer_extended_compare(&timer, NRF_TIMER_CC_CHANNEL1, PERIOD_1 * 1000UL, NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK, true);
    nrf_drv_gpiote_out_task_enable(BSP_LED_0);
    nrf_drv_gpiote_out_task_enable(BSP_LED_1);
 * @brief Function for application main entry.
    err_code = nrf_drv_timer_init(&timer, &timer_cfg, timer_dummy_handler);
#ifdef NRF51
    //Workaround for PAN-73.
    *(uint32_t *)0x40008C0C = 1;
    // Setup PPI channel with event from TIMER compare and task GPIOTE pin toggle.
    led_blinking_setup();
    // Enable timer
    nrf_drv_timer_enable(&timer);
    while (true)
        // Do Nothing - GPIO can be toggled without software intervention.
