SDK 12.1.0 and BLE Proximity Example with SAADC
Hi everyone,
I wanted to test out SAADC using the ble_app_proximity example using the nRF52-DK but I am having some issues. I modified the example with the below changes:
#define BATTERY_LEVEL_MEAS_INTERVAL       APP_TIMER_TICKS(1000, APP_TIMER_PRESCALER)    // changed from 120000 to 1000
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);      // changed so that the ADC is read from P05
I made 'adc_result' as a global variable and I put an if statement in the main loop so that P31 outputs high if adc_result > 0. However, no changes are seen when I connect VDD with P05.
Am I doing something wrong here?
Thank you.
    Did you connect to the device and enabled notifications for the battery service? Notice that the timer for battery measurement is first started in the bas event handler, on_bas_evt(), on the event BLE_BAS_EVT_NOTIFICATION_ENABLED.
    You can move the starting of the timer to timers_init function or somewhere else, if you want to continuously measure the battery current.
    Jørgen
