nrf51 Radiated Emissions Fail
Hi, we are using nRF51822-QFAA in our project which is based on the PCA10000-nRF51822 Development Dongle 2.0 - layout of radio part is almost the same. I'm also using sdk v6.1.0 with s110_nrf51822_7.3.0_softdevice. Then I've prepared application which is based on radio_test_example with ability to configure radio to transmit on different static channels (top, middle and bottom) and send it to the lab. And finally the result is failed. As you can see in the graph attached (www.dropbox.com/.../RE1 FAIL 1-25GHz High CH.png, the harmonics of the transmitter exceed the limit. Marker number 12, the 2nd harmonic, is the highest measurement exceeding the average limit by +4dB. In addition to the harmonics, there appears to be a spurious emission at marker #11, 2565MHz which when the average was measured it exceeded the average limit by +7dB. So do you have any ideas what may cause that?
