Power Profiling Kit RTT Documentation?
We would like to use the PPK for automating some of our tests. Is there any documentation on how to drive the PPK over RTT? If push really comes to shove, we can always read what's in ppk.py, but it would be easier if there's some semi-official documentation.
I know that Nordic is planning on releasing a Python API for the PPK, but we'd like to keep all of our in-house software in C#. We already have a C# wrapper around the jlink dll and would like to use that.
I think I'll keep a running log of what all I've done here.
Initialization
First thing is you have to connect to the PPK with nrfjprog and start RTT. It's pretty straight forward. I'm using the C interface which can be found at (on Windows) Program Files (x86)\Nordic Semiconductor\nrf5x\bin\headers\nrf52_nrfjprogdll.h
  1. Open the nrfjprog library dll by calling NRFJPROG_open_dll
  2. Connect to the Jprog emulator / debugger. NRFJPROG_connect_to_emu_with_snr or NRFJPROG_connect_to_emu_without_snr
  3. Perform a system reset. NRFJPROG_sys_reset
  4. Call NRFJPROG_go
  5. Start the RTT Service. NRFJPROG_rtt_start
  6. Wait 1 second. This is a critical step and things don't work unless you do so.
At this point, you're ready to do your first read. Read 200 characters over RTT by calling NRFJPROG_rtt_read. All reads and writes over RTT use channel 0. Assuming everything worked correctly, the PPK should return something along these lines:
CALIBRATED R1:510.000 R2:28.000 R3:1.800 Board ID 21F3171D
USER SET R1:510.000 R2:28.000 R3:1.800
Refs VDD: 3092 HI: 4941 LO: 27195
I'm trying to work through the startup sequence in the Python code after the calibration values are read back. pms_plotter.start() in ppk.py uses the values read above to setup the windows and controls. From there, it issues the RTT_CMD_TRIGGER_SET, RTT_CMD_RUN, and RTT_CMD_AVG_NUM_SET`. I haven't traced the code further.
I did insert a log-to-file in the rtt.write_stuffed function to log the raw bytes sent to the PPK. Here's what the complete startup command sequence looks like:
02 1f 23 1f 22 00 03 //RTT_CMD_TRIG_WINDOW_SET with value 0x02000
02 01 1f 22 00 03     //RTT_CMD_TRIGGER_SET with value 0x02000
02 06 03                  //RTT_CMD_RUN
02 1f 22 00 01 03     //RTT_CMD_AVG_NUM_SET with value 0x0001
02 0c 00 03              //RTT_CMD_DUT with value 0x00.  I think it disconnects the inputs for calibration?
02 0c 01 03              //RTT_CMD_DUT with value 0x01.  I think it reconnects the inputs after calibration?
The first 5 commands (RTT_CMD_TRIG_WINDOW_SET, RTT_CMD_TRIGGER_SET, RTT_CMD_RUN, RTT_CMD_AVG_NUM_SET, and RTT_CMD_DUT with value 0x00) are sent in rapid succession, one after another. The code waits for 1 second to gather data points with the input disconnected to generate an offset / calibration value. The second RTT_CMD_DUT re-enables the inputs so the PPK can start.
It looks like the PPK is sending back current samples as floats with uA units. Here's the code from the PPK that parses the bytes coming back.
         data = self.nrfjprog.rtt_read(0,10000, encoding=None)
                if data != '':
                    for byte in data:
                        n = byte
                        if self.read_mode == MODE_IDLE:
                            ''' Mode Idle - Not Receiving '''
                            if n == STX:
                                self.read_mode = MODE_RECV
                        elif self.read_mode == MODE_RECV:
                            ''' Mode Receiving - Receiving data '''
                            if n == ESC:
                                self.read_mode = MODE_ESC_RECV
                            elif n == ETX:
                                self.callback(data_buffer)
                                data_buffer[:] = []
                                self.read_mode = MODE_IDLE
                            elif n == STX:
                                data_buffer[:] = []
                            else:
                                data_buffer.append(n)
                        elif self.read_mode == MODE_ESC_RECV:
                            ''' Mode Escape Received - Convert next byte '''
                            data_buffer.append(n ^ 0x20)
You'll typically get 4 bytes when self.callback() is called. Those 4 bytes are a float in what I think is little endian format. I'm taking an educated guess that each sample covers 15us, because the documentation says the resolution goes down to 15us.
You'll also see really long byte arrays getting passed to the callback. Those are most likely values for the trigger window. I haven't looked at the trigger-related stuff closely. Sending the RTT_CMD_TRIG_STOP command completely stops those long arrays from showing up.
  • No, there are no RTT documentation for the PPK interface. It is quite easy to disect the python file, and look at (for instance) the RTT commands:
        RTT_CMD_TRIGGER_SET         = 0x01
        RTT_CMD_AVG_NUM_SET         = 0x02
        RTT_CMD_TRIG_WINDOW_SET     = 0x03
        RTT_CMD_TRIG_INTERVAL_SET   = 0x04
        RTT_CMD_SINGLE_TRIG         = 0x05
        RTT_CMD_RUN                 = 0x06
        RTT_CMD_STOP                = 0x07
        RTT_CMD_RANGE_SET           = 0x08
        RTT_CMD_LCD_SET             = 0x09
        RTT_CMD_TRIG_STOP           = 0x0A
        RTT_CMD_CALIBRATE_OFFSET    = 0x0B
        RTT_CMD_DUT                 = 0x0C
        RTT_CMD_SETVDD              = 0x0D
    and how to send them (rtt.py).
    rtt.write([RTT_COMMANDS.RTT_CMD_RUN])
       def write(self, cmd):
            try:
                s = []
                s.append(STX)
                for byte in cmd:
                    if byte == STX or byte == ETX or byte == ESC:
                        s.append(ESC)
                        s.append(byte ^ 0x20)
                    else:
                        s.append(byte)
                s.append(ETX)
                try:
                    self.nrfjprog.rtt_write(0, s, encoding=None)
                    self.nrfjprog.write_u32(NRF_EGU0_BASE + TASKS_TRIGGER0_OFFSET, 0x00000001, 0)
                    self.nrfjprog.go()
                except Exception as e:
                    raise
    Hopefully there will be an API coming soon. If there are any specifics you wonder about, please ask, and I will do my best to answer them.
  • I have a few questions:
    1. Occasionally, the PPK will return all 0's when trying to read the Board ID, calibrations values, etc. My code goes through these steps :
    a) Connect to the debugger at the max SWD speed. NRFJPROG_connect_to_emu_with_snr
    b) Connect to the device. NRFJPROG_connect_to_device
    c) Call system reset. NRFJPROG_sys_reset
    d) Call go. 'NRFJPROG_go`
    e) Start RTT. NRFJPROG_rtt_start
    f) Wait for the RTT Control block to be found. Does a spin wait loop calling NRFJPROG_rtt_is_control_block_found until found is true. g) Read 200 characters over RTT. This will occasionally return all 0s.
    The only difference I see between my startup code and the PPK Python code is the Python code calls time.sleep(1), where my code waits for the RTT control block. Should I just wait for 1 second instead of looking for the RTT control block?
  • Scratch all of my questions. It appears that 1 second wait after calling NRFJPROG_rtt_start is critical for proper PPK operation. I have no idea why.
  • That wait is critical for RTT operation in general. I don't know what has to settle, but yes, I have seen this as well.
  • @wilhelmsen I think I have the reading values back working. Do you know what the time span each sample covers? I'm making the assumption that it's 15us because that's what [the documentation says], but I can't find anything definitive in the python code.
    (infocenter.nordicsemi.com/.../PPK_user_guide_Intro.html
