Directed (fast) advertising timeout and scanning at low power
We have an nRF51822 peripheral device that is bonded with one and only one central. The central is always an iOS or Android phone running our app, which is scanning at "low power", whatever that means for each mobile platform.
For Android (at least 5.0 through 7.1), low power means:
private static final int SCAN_MODE_LOW_POWER_WINDOW_MS = 500;
private static final int SCAN_MODE_LOW_POWER_INTERVAL_MS = 5000;
(See: android.googlesource.com/.../ScanManager.java
(I'm not aware of the equivalent values for iOS, but perhaps someone can enlighten me)
So an Android central of ours will only have the radio on 10% of the time. And, as explained here (devzone.nordicsemi.com/.../) each scan is on a different one of three channels. So we would need to be advertising for 15s in order to be reasonably sure of a connection and have scanning coincide with advertising at least once on each channel. Am I right so far?
If so, it would seem that directed advertising (fast) in this situation is pretty much useless because it's so short. How long is it, actually? I know it's really intended for situations when you've just lost a connection and the central is in fact doing higher powered scanning. Just looking for confirmation I've got this right.
  • High duty cycle directed advertising the advertising interval is less than 3.75ms, and is usually used just after a link loss, because then you know that the scanner is actually scanning, so that you don't waste power spamming advertisments when there is noone listening. It can be used in other scenarioes, but it is an extreme measure, where latency is important, but power consumption is not.
