recommend battery measuring method
Hi all,
From this forum and the examples given in the "sdk" find two approaches to measuring the battery voltage:
  • using external divider 10M/2.2M+22nF
  • using integrated divider 1:3 of VCC. The first method uses additional components and has even a small additional power consumption. In the source code of second method I see compensation of voltage drop over diode (can't find this diode in the datasheet). Тhis is likely to cause an increase in the error. What is the exact value of voltage drop and how repetitive it is in different ICs.
Which method do you recommend?
Best regards, Peter
