Buttonless DFU example with custom service UUIDs
I have a standalone application which incorporates 3 public BLE services and 2 services with custom UUIDs. Today I tried to extend the buttonless DFU example with these services. Everything works fine unless I try to add my custom services. I get "APP_ERROR:ERROR:Fatal" in UART Log. Is there some kind of switch to make the softdevice only accept public UUIDs? Unfortunately I had no luck debugging the application since the secure bootloader is involved. The application without booloader/buttonless DFU service works just fine.
I use SDK 12.1.0 on nRF51.
Here is my init function of one of my custom services:
void lum_service_init(ble_lum_t * p_our_service)
  /* Service */
  uint32_t   err_code;
  ble_uuid_t        service_uuid;
  ble_uuid128_t     base_uuid = BLE_UUID_OUR_BASE_UUID;
  service_uuid.uuid = BLE_UUID_LUM_SERVICE;
  err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid.type);
  err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                    &service_uuid,
                                    &p_our_service->service_handle);
  ble_uuid_t          char_uuid;
  char_uuid.uuid      = BLE_UUID_LUM_CHARACTERISTC_UUID;
  err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type);
  /* Characteristic */
  ble_gatts_attr_md_t attr_md;
  memset(&attr_md, 0, sizeof(attr_md));
  attr_md.vloc        = BLE_GATTS_VLOC_STACK;               /* store metadata in SoftDevice */
  BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);       /* allow reading of values */
  BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);      /* allow writing of values */
  /* Characteristic Value Attribute  */
  ble_gatts_attr_t    attr_char_value;
  memset(&attr_char_value, 0, sizeof(attr_char_value));
  attr_char_value.p_uuid      = &char_uuid;
  attr_char_value.p_attr_md   = &attr_md;                     /* assign attribute metadata to characteristic value attribute */
  attr_char_value.max_len     = 4;                            /* max value length */
  attr_char_value.init_len    = 4;                            /* initial value length */
  attr_char_value.p_value = (uint8_t*)&Luminosity;                            /* ptr to actual value */
  /* Characteristic Metadata  */
  ble_gatts_char_md_t char_md;
  memset(&char_md, 0, sizeof(char_md));
  char_md.char_props.read = 1;                                /* set read property */
  char_md.char_props.write = 0;                               /* set write proper */
  err_code = sd_ble_gatts_characteristic_add(p_our_service->service_handle,
                                     &char_md,
                                     &attr_char_value,
                                     &p_our_service->char_handles);
And here is my ble_lum_t typedef:
typedef struct
  uint16_t                    conn_handle;    /* handle to keep track of the current connection */
  uint16_t                    service_handle; /**< Handle of Our Service (as provided by the BLE stack). */
  ble_gatts_char_handles_t    char_handles;   /* characteristics handle */
}ble_lum_t;
I use
#define BLE_UUID_OUR_BASE_UUID              {0x23, 0xD1, 0x13, 0xEF, 0x5F, 0x78, 0x23, 0x15, 0xDE, 0xEF, 0x12, 0x12, 0x00, 0x00, 0x00, 0x00} // 128-bit base UUID
as base UUID for all custom services and a random 16-Bit value for the service itself:
#define BLE_UUID_LUM_SERVICE                0xABCE // Just a random, but recognizable value
and for the characteristics:
#define BLE_UUID_LUM_CHARACTERISTC_UUID                          0xBEF0
Can you tell me whats wrong?
Thank you very much!
