Hi
I'm trying to get higher throughput when connected as a central by increasing my Tx&Rx bandwidth to high (from the default medium).
uint32_t nrfErr; ble_opt_t opt = {0};
/* Set the role as central */
opt.common_opt.conn_bw.role = 2;
/* Set the transmit bandwidth to be high */
opt.common_opt.conn_bw.conn_bw.conn_bw_tx = 3;
/* Set the receive bandwidth to be high */
opt.common_opt.conn_bw.conn_bw.conn_bw_rx = 3;
nrfErr = sd_ble_opt_set(BLE_COMMON_OPT_CONN_BW, &opt);
I've left the bandwidth configuration to NULL when enabling the softdevice as follows:-
ble_enable_params_t enable_params;
enable_params.common_enable_params.p_conn_bw_counts = NULL;
However, with the above configuration I did not see any change in throughput and it seems that the bandwidth has not been effectively changed. Should the p_conn_bw_counts be changed to value other than NULL? and if that's the case what's the value that can get us the maximum throughput as a central?
We're using an nrf52 with softdevice 132 v3.0.0
Thanks
