SDK12 Pstorage (Solution)
Hi, SDK12 does not have Pstorage. I want to show you how to add it.
Steps:
  1. Copy the pstorage folder in SDK11 into the SDK12 \components folder.
  2. Open any project in SDK12
  3. Add pstorage.c in nRF_Libraries on the project side.
    image description
  4. Keil, Options for Target -> C/C++ Tab inside
image description
Okay.
its now code time:
  1. Added library in to main.c
    #include "pstorage.h"
  2. Added Initalize Event functions
     static void sys_evt_dispatch(uint32_t sys_evt)
    { pstorage_sys_event_handler(sys_evt);
  3. Added Flash Read/Write Codes (handle,update and only read functions)
     static uint8_t pstorage_wait_flag = 0;
    static pstorage_block_t pstorage_wait_handle = 0; static void flash_cb_handler(pstorage_handle_t * handle, uint8_t op_code, uint32_t result, uint8_t * p_data, uint32_t data_len) { if(handle->block_id == pstorage_wait_handle) { pstorage_wait_flag = 0; } //If we are waiting for this callback, clear the wait flag.
     	switch(op_code)
     		case PSTORAGE_LOAD_OP_CODE:
     			 if (result == NRF_SUCCESS)
     					 bsp_indication_set(BSP_INDICATE_ALERT_0);
     					 bsp_indication_set(BSP_INDICATE_RCV_ERROR);
     		case PSTORAGE_STORE_OP_CODE:
     					 bsp_indication_set(BSP_INDICATE_ALERT_1);
     		case PSTORAGE_UPDATE_OP_CODE:
     					 bsp_indication_set(BSP_INDICATE_ALERT_2);
     		case PSTORAGE_CLEAR_OP_CODE:
     					 bsp_indication_set(BSP_INDICATE_ALERT_3);
     	uint8_t                 dest_data_0[16];
     	uint8_t                 dest_data_1[16];
     	uint8_t                 dest_data_2[16];
    void read_flash() { pstorage_handle_t handle; pstorage_handle_t block_0_handle; pstorage_handle_t block_1_handle; pstorage_handle_t block_2_handle; pstorage_module_param_t param;
     	uint32_t                retval;
     			retval = pstorage_init();
     	if(retval != NRF_SUCCESS)
     			bsp_indication_set(BSP_INDICATE_FATAL_ERROR);
     	param.block_size  = 16;                   //Select block size of 16 bytes
     	param.block_count = 4;                   //Select 10 blocks, total of 160 bytes
     	param.cb          = flash_cb_handler;   //Set the pstorage callback handler
     	retval = pstorage_register(&param, &handle);
     	if (retval != NRF_SUCCESS)
    // //Get block identifiers
     	pstorage_block_identifier_get(&handle, 2, &block_2_handle);
     	//Clear 100 bytes, i.e. one block
     	retval = pstorage_clear(&block_0_handle, 48);
     	if(retval != NRF_SUCCESS)  { bsp_indication_set(BSP_INDICATE_RCV_ERROR); }
     	//Store data to three blocks. Wait for the last store operation to finish before reading out the data.
     	pstorage_load(dest_data_2, &block_2_handle, 16, 0);
    } static void pstorage_test_store_and_update(void) { pstorage_handle_t handle; pstorage_handle_t block_0_handle; pstorage_handle_t block_1_handle; pstorage_handle_t block_2_handle; pstorage_module_param_t param; uint8_t source_data_0[16] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F}; uint8_t source_data_1[16] = {0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19, 0x1A, 0x1B, 0x1C, 0x1D, 0x1E, 0x1F}; uint8_t source_data_2[16] = {0x20, 0x21, 0x22, 0x23, 0x24, 0x25, 0x26, 0x27, 0x28, 0x29, 0x2A, 0x2B, 0x2C, 0x2D, 0x2E, 0x2F}; uint8_t source_data_9[16] = {'7', '2', 'C', 'D', 'E', 'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', '9', '\0'}; uint8_t dest_data_0[16]; uint8_t dest_data_1[16]; uint8_t dest_data_2[16]; uint32_t retval;
    // //Get block identifiers pstorage_block_identifier_get(&handle, 0, &block_0_handle); pstorage_block_identifier_get(&handle, 1, &block_1_handle); pstorage_block_identifier_get(&handle, 2, &block_2_handle);
     	pstorage_store(&block_0_handle, source_data_0, 16, 0);     //Write to flash, only one block is allowed for each pstorage_store command
     	pstorage_store(&block_1_handle, source_data_1, 16, 0);     //Write to flash, only one block is allowed for each pstorage_store command
     	pstorage_wait_handle = block_2_handle.block_id;            //Specify which pstorage handle to wait for
     	pstorage_wait_flag = 1;                                    //Set the wait flag. Cleared in the example_cb_handler
     	pstorage_store(&block_2_handle, source_data_9, 16, 0);     //Write to flash
     	while(pstorage_wait_flag) { power_manage(); }              //Sleep until store operation is finished.
     	pstorage_load(dest_data_0, &block_0_handle, 16, 0);				 //Read from flash, only one block is allowed for each pstorage_load command
     	pstorage_load(dest_data_1, &block_1_handle, 16, 0);				 //Read from flash
     	pstorage_load(dest_data_2, &block_2_handle, 16, 0);			   //Read from flash
     	pstorage_wait_handle = block_0_handle.block_id;            //Specify which pstorage handle to wait for
     	pstorage_clear(&block_0_handle, 32);                       //Clear 32 bytes
     	pstorage_update(&block_0_handle, source_data_9, 16, 0);    //update flash block 0
       while(pstorage_wait_flag) { power_manage(); }              //Sleep until update operation is finished.
