Ready to development TWI application while using softdevice
Hi, I am developing a BLE application using SPI and TWI. (Using nRF51822) This discussion is about my survey in development zone for future develop the TWI part. I want to discuss... not just ask some specific question ;)
I've used SPI slave to read another chip's information, and transmit these information through BLE. And I want to read another chip's information (through TWI) and also try to send other relatively few and less important information through BLE.
Since I've not found the TWI hw sample code. And I read this: devzone.nordicsemi.com/.../twi-of-nrf51822-is-having-internal-twi-engine-or-not And know I can just use GPIO to simulate the TWI behavior. But is any shortcoming using TWI sw module? The SPI part is a real-time data flow application (SPI->BLE). I am not sure using TWI sw will causing more CPU computation thus loss some interrupt from SPIs? Even I've setting SPI MATRX 255.
Is TWI hw more recommand?
The other thing I thought is the Peripheral ID. As reference manual says, ID:4 is used by SPI slave so I've to use ID:3 (TWI0) as my application. I think I can just modify the code in the library NRF_TWI1 => NRF_TWI0
Is that enough?
And I've read more about the confilct between TWI and the softdevice. The reason is using the restricted PPI for shortcut BB-suspend and BB-stop when softdevice is enabled.
And I read this: devzone.nordicsemi.com/.../using-i2c-gpiote-interrupt-with-soft-device-enabled As Ole says, the new version chip can simply enable these shortcut without PPI configuration. The sample code in [sdk 5.1.0 36092] is also using PPI.
If I want to modify these below without using PPI: sd_ppi_channel_assign(0, &(NRF_TWI1->EVENTS_BB), &(NRF_TWI1->TASKS_STOP)); sd_ppi_channel_assign(0, &(NRF_TWI1->EVENTS_BB), &(NRF_TWI1->TASKS_SUSPEND)); sd_ppi_channel_enable_set(PPI_CHEN_CH0_Msk); sd_ppi_channel_enable_clr(PPI_CHEN_CH0_Msk);
as I thought I've to enable these shortcut first:
NRF_TWI0->SHORT = TWI_SHORTS_BB_STOP_Msk | TWI_SHORTS_BB_SUSPEND_Msk;
And then I don't know how to modify these tasks start..... I guess "channel_enable_set" can transfer as setting the task = 1 (Example: NRF_TWI0->TASKS_SUSPEND = 1) And the channel_enable_clr can transfer as the setting task = 0
Is that correct?
Finally, as I've read the PAN and know TWI will consume more power when enabled. To reduce power consumption, It is recommend to disabled when not used. Since the NVIC interrupt is not set in the sample code (twi_xx_master.c) I think disable TWI only use a function with below code is enough.
NRF_TWI1->ENABLE = TWI_ENABLE_ENABLE_Disabled << TWI_ENABLE_ENABLE_Pos; NRF_TWI1->POWER = 0;
Is that correct? And I know while enabled it again, it must needs to initialize first.
If something I didn't notice, please tell me. Thanks a lot!
  • Yup - have triple checked - G0. Have tried on multiple nRF51822-QFAAG0 parts. Using latest (just this week) SDK drop - and the 6.0.0 S110 SoftDevice.
    I am using a custom PCBA - it has an InvenSense part as well as a Serial Flash onboard - that's pretty much it.
    It seems like it is able to do a few (like 3 or 4) TWI operations - but then gets into this block of code - and never seems to recover (TWI functionality that is).
        if (timeout == 0 || NRF_TWI1->EVENTS_ERROR != 0)
          // Recover the peripheral as indicated by PAN 56: "TWI: TWI module lock-up." found at
          // Product Anomaly Notification document found at
          // www.nordicsemi.com/.../
          NRF_TWI1->EVENTS_ERROR = 0;
          nrf_delay_us(5);
          NRF_TWI1->POWER = 1;
          NRF_TWI1->ENABLE = TWI_ENABLE_ENABLE_Enabled << TWI_ENABLE_ENABLE_Pos;
          (void)twi_master_init();
          return false;
    I've not had the time to delve into it further than just running in debugger and seeing that it finds it's way into the PAN 56 lock-up condition - which the twi_SD_master.c driver never does.
  • Hi Tim, did you end up resolving your TWI issue? It looks like I may have the same problem...
