Interfacing HX711 for Weigh Sensors using nRF51 BLE
Hi, I am interfacing HX711- 24 bit ADC for Weigh Scale to calculate weight which has DOUT and PD_SCLK for Digital Output and Digital Input. I have the working Arduino code and I need to convert this code for nRF BLE_UART .Can anyone help me out with this?
I have attached the Arduino code with this
long readIndex = 0;              // the index of the current reading
long total = 0;                  // the running total
double average = 0;                // the average
void setup()
  Serial.begin(9600);
  Serial.println(" HX711 ");
  Serial.println("Before setting up the scale:");
  Serial.print("read: \t\t");
  Serial.println(scale.read());     // print a raw reading from the ADC
  Serial.print("read average: \t\t");
  Serial.println(scale.read_average(20));   // print the average of 20 readings from the ADC
  Serial.print("get value: \t\t");
  Serial.println(scale.get_value(5));   // print the average of 5 readings from the ADC minus the tare weight (not set yet)
  Serial.print("get units: \t\t");
  Serial.println(scale.get_units(5), 1);  // print the average of 5 readings from the ADC minus tare weight (not set) divided
            // by the SCALE parameter (not set yet)
  scale.set_scale(2280.f);                      // this value is obtained by calibrating the scale with known weights; see the README for details
  scale.tare(20);               // reset the scale to 0
  Serial.println("After setting up the scale:");
  Serial.println(scale.get_value(5));   // print the average of 5 readings from the ADC minus the tare weight, set with tare()
  Serial.println(scale.get_units(5), 1);        // print the average of 5 readings from the ADC minus tare weight, divided
            // by the SCALE parameter set with set_scale
  Serial.println("Readings:");
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
long c=0;
double w=0;
long x=0;
long y=0;
long z=0;
void loop()
   Serial.print("     ");
   y=scale.read();
   Serial.print(y);
    Serial.print("     ");
      Serial.print("     ");
   Serial.print(x);
    Serial.print("     ");
   z=y-x;
   Serial.print(z);
    Serial.print("     ");
 w=9.132*0.00001*0.00001*0.00001*0.0001*z*z*z-4.537*0.00001*0.00001*0.01*z*z+4.449*0.00001*z;
    Serial.print("weight=     ");
   Serial.println(w);
   if (Serial.available() > 0)
      incomingByte = Serial.read();
      if(incomingByte==49)
          x=y;
          Serial.println("   Tare complete     ");
   delay(300);
Regards.
