Zip file failed to upload for ble_secure project
Hello, I am working on ota ble_secure project. I have created a zip file which is the last step and copied this file to my smart phone so that I can upload it using nrf toolbox. The upload fails. I am not sure which files to include to create a zip package. I am attaching my zip package as well as the files that I used to merge.app_dfu_package.zip. The hex file is nrf52832_xxaa_s132.hex.
The log file of error is log.txt
Sdk which I have is www.nordicsemi.com/.../nRF5-SDK
I am using this project in sdk sdknordic\examples\dfu\bootloader_secure\pca10040
Log file New Text Document.txt
New log file errorlog.txt
    Please add more information on the SDK version you use, how you generate the .zip file
    What error you have when the updating failed ? You can find a log file using nrfLogger app
  • I am using nrf51latest13alpha this sdk and in that I am trying ble-secure given in examples. It says dfu process failed. I dont know hot nrf logger works. I am generating my zip file by using the commands nrfutil pkg generate --debug-mode --application (location of hex file and file is attached) --key-file (location of my .pem file) app_package.zip.
  • Have you updated the bootloader with your public key ?
    Have installed nRFLogger on your phone ? You should be able to find the trace inside that app.
    You can also test with the test .zip file inside test_image_update_nrf52, when you test that you would need to use the debug bootloader project with the original key.
  • I am following pcbreflux.blogspot.in/.../nrf51822-secure-dfu-ota-via-ble.html this project. I did everything given here including updating the public key. I am faing challenge in generating zip package. In the following command nrfutil pkg generate --debug-mode --application dfu_app.hex --key-file ../my_secret_private_key.pem app_package.zip where will I find the hex file for this project? Currently I used the hex file generated in build and I think they are using some other file to generate. I have uploaded dual_bank_ble_s132 firmware in my nrf52. Do I need to make changes in that project? I uploded this so that it starts advertising and I can see dfutarg in my nrfconnect app. Thanks,
    You can also follow the instruction in our documentation here.
    The dfu_app.hex is the hex that you generate when you compile your application.
    I assume you have updated the public key in the bootloader , compiled it and used that bootloader.
    You would need to tell me how it failed when doing DFU. The nRFLoger would help. Or you would need to capture a sniffer trace when you do the process.
    In addition, you can enable NRF_LOG in the DFU bootloader so that it will print UART log when doing DFU.
