Looking for a reason flash might be 0xff's after OTA DFU
Hi, I'm trying to install the BLE buttonless DFU template onto a nRF52 (PCA10040) eval board using the secure bootloader example (with s132, version 12.2 of the SDK) via nRF Toolbox. There's no application there to begin with, but I've specified that in the bootloader settings. The process seems to go correctly (takes about 30 seconds, progress bar moves smoothly) and the toolbox gives a message that upload is complete. After that, I'd expect to find application code in flash starting at 0x1f000, but it's all 0xff's. I'm attaching the output from nrfutil pkg display for the app. Is there some common mistake that would lead to this situation? Thanks very much.pkg.txt
Edit: I ran the debug build of the bootloader and I am seeing what looks like a successful transfer but a bunch of erases after reset and a CRC error. I'm attaching the log. Thanks for any insight! errorlog.txt
Edit 2: As requested, here is the full hex dump and app package file. template5.zip nrf52_hexdump.txt.zip
Edit 3: I tried the process using the example bootloader (secure_dfu_secure_dfu_ble_s132_pca10040_debug.hex) and sample zip file (dfu_test_app_hrm_s132.zip) and got the same failure. For clarity (and because I think I'm still making a simple mistake) here are the steps I took: (1) source bin/activate (2) nrfutil settings generate --family NRF52 --bootloader-version 1 --bl-settings-version 1 blsettings.hex (3) mergehex -m secure_dfu_secure_dfu_ble_s132_pca10040_debug.hex blsettings.hex -o bootloaderpkg.hex (4) nrfjprog --eraseall -f nrf52 (5) nrfjprog --reset --program bootloaderpkg.hex --family NRF52 (6) Turn off eval board and turn back on holding down button 4 (7) Start up JLinkExe and JlinkRTTClient for logging purposes (8) transfer dfu_test_app_hrm_s132.zip from iPhone using nrf toolbox. When I do that, I get this log exampleprogramlog.txt
  • Hi Tom,
    From the log , it seems the CRC comparison returned invalid. The CRC of the image copied to 0x1f000 doesn't match with the crc from bank 1. This is pretty strange. Could you read the whole hex dump after you do DFU and send me that ? You may want to include the .zip file you used .
    If you try with the test .zip example and the debug version of the bootloader, would it work ?
  • Thanks very much Hung Bui. I've attached the hex dump and app package. I'm sure I've just made a simple mistake. I'll try dfu_test_app_hrm_s132.zip with the default debug bootloader from the sdk?
  • @Tom: the example .zip is located at \examples\dfu\ble_dfu_send_hex\test_images_update_nrf52832.
    I just had a look into your hex file, seems that the whole 2 banks are empty. You sure you don't do any flash erasing with your application ?
    Besides testing with the example .zip file, you can also try to test with the example in the SDK such as the ble_app_hrs.
    Where did you set the start address of your bootloader ?
  • @Hung Bui: I'm starting to wonder if I'm using the DFU mechanism correctly. I start by clearing the flash, then programming the s132 and bootloader-plus-settings hexfile using nrfjprog via J-Link. The bootloader should start at 0x75000 because I haven't changed the linker settings. At this point, there's no application (and the bootloader settings were generated with no --application specified). Then I transfer the application via nRF Toolbox. Please see edit 3 above for testing with SDK example.
  • Hi Tom,
    I don't know why you need step 2, generating the bootloader setting ? It's not in the instruction in the doc. You only genrate the bootloader setting and merge it when you want to merge the application and flash the application with the bootloader at the same time.
    To test with the stock .zip in the SDK, please simply:
    • Compile the debug bootloader
    • Flash the softdevice and then the bootloader
    • Check if the bootloader advertising, then do DFU update from nRFToolbox or NRFConnect
