"region RAM overflowed with stack" error while using TLS
Hello everyone,
I am using nrf52832 with SDK version 11.0 for an IoT application. I am communicating with Atmel ATWINC 1500 module through SPI in order to connect to Wifi. First I faced memory issues using SPI which were fixed by setting heap size to 0 as suggested in this thread. Now when I enable TLS for mqtt communication I get region RAM overflowed with stack. I have tried changing stack to 16kB with heap as 0 and also tried with various other combinations of stack and heap but the error stays the same. My .map file,make file and startup file is attached for reference. I am not using any soft device so is there any way of making TLS work by utilizing maximum available RAM?
nrf52832_xxaa.map Makefile arm_startup_nrf52.s
  • I don't have too much experience with gcc, but you can find it here:
    .heap           0x2000fd40      0x200
                    0x2000fd40                __end__ = .
                    0x2000fd40                PROVIDE (end, .)
     *(.heap*)
     .heap          0x2000fd40      0x200 _build/gcc_startup_nrf52.o
                    0x2000fd40                __HeapBase
                    0x2000ff40                __HeapLimit = .
    .stack_dummy    0x2000fd40     0x3c00
     *(.stack*)
     .stack         0x2000fd40     0x3c00 _build/gcc_startup_nrf52.o
                    0x20010000                __StackTop = (ORIGIN (RAM) + LENGTH (RAM))
                    0x2000c400                __StackLimit = (__StackTop - SIZEOF (.stack_dummy))
                    0x20010000                PROVIDE (__stack, __StackTop)
                    0x00000000                ASSERT ((__StackLimit >= __HeapLimit), region RAM overflowed with stack)
  • Great! I converted my comment to an answer, please consider accepting it by clicking the grey circle next to it. If you have unrelated questions please add them separately, so you should add a new question.
