USB out endpoint maximum size of one packet
Hi,Nordic I have one nRF24LU1P device, when I make it as USB Dongle, I will use :
hal_usb_endpoint_config(uint8_t ep_num, uint8_t ep_size, hal_usb_cb_endpoint_t endpoint_isr)
from this function comment:
/** Function to register callbacks for given endpoints
  • To register a callback one have to have a function with an argument list equal to usb_endpoint_cb_t.
  • @param ep_num Endpoint number. If MSB is set it indicates this is an IN endpoint.
  • @param ep_size The maximum size of one packet for this endpoint
  • @param endpoint_isr Pointer to function that is called when host issues a request on the given endpoint. Set to 0 to unregister function. */
but for param ep_size, it only :
// Dummy use of variable to get rid of warning
ep_size = 0;
why only set size to 0?  If this, I can not change size, right?  If I want to use custom usb in/out endpoint size, how could I do?
Thanks
