nrf51822 pwm working some minutes will loss.
APP_PWM_INSTANCE(PWM1,1);
void PWM_init(void)
    u32 err_code;
    app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(1000, 8);
    err_code = app_pwm_init(&PWM1,&pwm1_cfg,NULL);
    app_pwm_enable(&PWM1);
    while (app_pwm_channel_duty_set(&PWM1, 0, 0) == NRF_ERROR_BUSY);
void PWM_Set( u8 duty )
    if ( duty>100 )    duty = 100;
    while (app_pwm_channel_duty_set(&PWM1, 0, duty) == NRF_ERROR_BUSY);
hi,anybody! I have a issue When a device receives the bluetooth data will set the function PWM_Set() , duty take any value.
  • What do you mean by lost? You mentioned Bluetooth in your question, are you using a SoftDevice? Does it work without a SoftDevice? Please try to explain some more. You can also edit your question and upload your complete project, so I can test it here.
