i am trying to build the project blinky in eclipse as per the tutorial.. but it is getting error as shown in figure ... plz help me ...
The last line of the error message means: the Windows shell cannot find the 'mkdir' command. You can test whether mkdir is properly installed by typing 'mkdir foo' at a command line. Maybe you omitted the step of the tutorial where you install the gnu tools such as mkdir, or you failed to change your PATH so that the shell finds the installed tools.
thanku. now the make file error are done ... but the header and macros are not detected in main.c
If you have unrelated questions please add them separately, this should be a new question, not an answer.
Yes, you should please comment instead of answer.
I can't remember how the tutorial's Makefile works, but it may define a variable that points to where you installed the Nordic SDK (which contains the missing include files) and you might be able to change that variable in the Makefile. And Windows is funny about spaces in path names like "Program files", which might also be the problem. Or some of the folders in the Eclipse project might be soft "linked" folders and linked to non-existent locations.
