Problems when a high rate interrupt is connected
I am using the nrf52 development board, when I try to connect to one of its pins a signal from a sensor that generates an interrupt signal every 1ms the programs stops or it is restarted. Here is how I am doing it:
     nrf_gpio_cfg_sense_input(27, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
     err_code = nrf_drv_gpiote_init();	// Function for initializing the GPIOTE module.
     nrf_drv_gpiote_in_config_t config;
     memset(&config, 0, sizeof(nrf_drv_gpiote_in_config_t));
     config.sense =  NRF_GPIOTE_POLARITY_LOTOHI;
     config.pull = NRF_GPIO_PIN_PULLDOWN;
     config.hi_accuracy = true;
     config.is_watcher = false;
     err_code = nrf_drv_gpiote_in_init(27, &config, pin_event_handler);
     nrf_drv_gpiote_in_event_enable(27, true);
On the Interrupt handler I am just setting and clearing a led from the board. When I do the exact same procedure with another pin connected to one of the switches, it works fine. I don't know if maybe the interrupt frequency is to high. Does any one have an idea why this could be happening?
Is there any step that I am missing? Thanks in advance for your attention.
