MQTT stops responding after fixed number of subscribe and publish
Hi everyone,
I was having RAM overflowed with stack issues which were resolved using suggestions here. Now I am facing another issue. While running mqtt I can only do a fixed number (15) of mqtt publish or subscribe requests and then mqtt stops responding to received messages. I am suspecting this as a memory issue where stack pointer reaches an undefined location. Does anyone have any suggestion to debug such an issue while the project is running? Thanks a lot
  • Hi Jawad, the IoT SDK team has done major improvements to the MQTT library of the IoT SDK since the v0.9.x release. I have attached the latest MQTT library files from our internal repo below, could you try to replace the mqtt library and see if that resolves the issue?
    mqtt.zip
    Update 12.01.17
    I've added the mqtt files above to the MQTT publisher and subscriber gcc examples in the IoT SDK and verified that I am able to publish and subscribe to messages using a Raspberry Pi running the Mosquitto broker. I have attached the IoT SDK with the mqtt examples that uses the updated mqtt files.
    Note, I've only tested the examples using a non-secure connection, i.e. used the following configuration
    #define APP_MQTT_BROKER_PORT             1883
    m_app_mqtt_client.transport_type       = MQTT_TRANSPORT_NON_SECURE;
    m_app_mqtt_client.p_security_settings  = NULL;
    nrf5_iot_sdk_3288530_mqtt.zip
    Best regards
    Bjørn
  • Hi Bjorn, Thanks a lot for the continuous support. I will test the examples also using TLS.
