Hello, I'm looking into this particular issue and are now having some concerns. Namely:
My firmware size currently stands at 30k. It's not big, but definitely not small. For a successful dual bank update, I may need 30 X 2 (most ideal scenario) KBs of memory space. The problem is, a typical device, nrf51422 for example, has only a maximum 256kb of "embedded flash program memory". Considering the fact that an S110 softdevice alone is 249 kb in size (hex file, which suggests that the actual code will be smaller), will there be a problem when there is not enough memory to do a dual bank live DFU?
If there is not enough built-in memory to perform a live dual bank DFU, will an external flash chip have any complications? Is there something I must be cautious about?
Is there a configuration guide somewhere to which I can refer, on seamlessly integrate external SRAM and FLASH chips with embedded ones that came with the chip? To be more specific, how to properly configure keil IDE?
