Dual peripheral feature?
I see from the release notes of s132 4.0.0-2.alpha that it adds:
Support for 20 links in total with freely selectable role (Central/Peripheral) for each link.
I want to try this feature, but I can’t find any example for this in SDK 12.2.0 or SDK 13.0.0-1.alpha.
Anyone know if such an example exists?
  • Actually S132 4.0.0-2.alpha is not compatible with SDK 12.2.0 or SDK 13.0.0-1.alpha, but I made a minimalistic example that demonstrates the dual peripheral feature.
    I used ble_app_uart as a starting point, but I modified it so that two centrals can connect. Then if one client writes into the UART RX characteristic, the data will be notified to the other client, and vice versa.
    I added some logging to make it easy to see the reason, if anything is not working, for example that you haven’t connected two centrals, that you haven’t set the CCCDs to be able to receive notifications, and so on. So I recommend using a terminal on the PC.
    Please add a comment if you have trouble getting it to work.
    The example is not an official release, and is only tested with Keil and PCA10040, and this testing was very superficial.
  • 0x7 is NRF_ERROR_INVALID_PARAM - Invalid Client RX MTU size supplied, see documentation above sd_ble_gattc_exchange_mtu_request(). I see that you call sd_ble_gap_adv_start(&adv_params, 0), with conn_cfg_tag = 0? I think you need to use the tag you used in ble_stack_init(). So it should be something like sd_ble_gap_adv_start(&adv_params, CONN_CFG_TAG)
