Digital capacitors and NRF24L01+
Hi, possibly a bit of a stupid question but here we go:
I'm developing a prototype system, which includes my own design of sensor modules that transmit their data via nrf24l01+'s to a base station. One is located in a racket handle and, while is generally working, sometimes suffers from radio link problems. I read that having your device in an enclosure, and interaction of the body (hand in this case) can throw the tuning off.
When I've finished my prototyping I will take along what I've done to some professionals to make it market ready, including antenna and matching network tuning, as I don't have the knowledge or equipment to do a really good job. However, I was wondering if I could do a better prototype for field testing, using digitally tunable capacitors to try improving the link. I was inspired by reading pages like:
www.psemi.com/.../digitally-tunable-capacitors-dtc
electronicdesign.com/.../back-basics-impedance-matching-part-3
My thoughts would be to arrange the sensor/racket in various positions, chuck a load of data out to test link reliability (and counting number of retries, lost packets, etc...), with automation to test different DTC settings.
So my questions are:
  1. Would this work/be worth doing?
  2. If yes, is there any reference circuit designs I could look at that would be suitable for using the DTCs?
I'm thinking of including an RFX2401C for PA/LNA, and currently I'm using a chip antenna (Wurth 7488940245). In the racket sensor I could use a much longer antenna but I don't know what would be suitable.
So far I've been following as much as possible the Nordic reference designs.
Thanks for any help, Joe
  • Hi Joe,
    1. It would possibly work. But I guess you are using a PI tuning network here ? What if the tuning require one of the component be a inductor ?
    2. No we don't have one. I would suggest you to try using a PCB antenna instead, because it's easier to tune by simply use 1 shunt component and the length of the antenna as the 2nd factor to tune. We provided a tuning guide here.
    Side question, how is the radio performance currently on your board ? How bad is the "radio link problems" ?
  • Fantastic. Thanks very much for the support. Apologies for the delay in replying but I plan to get on with things this weekend. I did another field test a few days ago. It was better - perhaps because I implemented a channel scanner to pick the channel for the sensor, and a different environment. I'm encouraged by you message to have a go at the antenna.
    I was wondering about a different frequency range, but I would require quite a bit more than the 50kbps than the nRF905 can do unfortunately.
