Is there an example of a service with many characteristics ?
I need to have a custom service which allows configuration of multiple parameters (perhaps 50 or more - which control registers in external peripherals)
I've looked at the examples and existing services to see if there is anything similar, but all I can find is code where each characteristic has its own, rather large, setup function.
Is there an example of having an array of characteristics? (They don't even need to be named, they could just be numbered)
BTW. I had initially thought that I would just duplicate the UART service and put it on a private UUID, but I think the maximum data size for a single write or read from a service would not be large enough to hold 50 or more bytes if config data, and having the ability to read or write individual characteristics is more flexible.
Thanks.
  • I would not recommend having a service that has 50 or more characteristics. Adding that many characteristics will lead a very long service discovery time. My suggestion would be to hold the parameters internally, assign an identifier to each of the parameters and then use only two characteristics, one for the parameter value and one to identify which parameter that is to be updated. You can do the same procedure when you want to read out the values, write the identifier to one of the characteristics and configure the device to notify the value that corresponds to the identifier.
  • Hi Bjorn
    Thanks for the suggestion. I hadn't considered that the discovery would take a long time.
    I may use my original idea of using a modified version of the UART service, and have 2 separate WRITE (with response) characteristics. One characteristic would be the SET function, were parameter / data pairs of data are sent in the buffer,which set the register config for the peripherals (and some things to like advertising period etc)
    And another characteristic which performs the GET function, Write (with response), which receives just the parameter list, and responds with just the data for those parameters
    Just to complicate things further, I need to be able to prevent unauthorised modification of the parameters, so that anyone running Light Blue etc can't change random settings on the device.
    So I may need some sort of access enabling service as well.
  • You can restrict the access to read and write operations on the characteristics by setting security level for the individual characteristics, e.g. only bonded devices may read/write to certain characteristics.
  • Thanks Bjørn
    I will investigate whether traditional bonding will work in our particular circumstance, as each BLE device could be accessed by possibly hundreds of iOS devices, (in a large commercial setting), if requested by the server which controls the App.
    But, I suspect that the nRF51822QFAA we are using would run out of RAM storing all the keys needed for bonding to many iOS devices, and I'm also not sure how paring would be handled, as the iOS mainly runs in the background.
    I think I may have to implement a system where the iOS App reads a characteristic which contains a large random number, and the writes to another characteristic with the encrypted version of that number. The BLE device checks that the encrypted version of the last number read is correct, and then allows further communication (paramater SETs and GETs) from the currently connected device.
  • That is a possibility :) How frequently will the iOS devices connect to the BLE device? You have the possibility to delete the oldest bonding data if there is not enough memory and a iOS device connects, but this will require the iOS devices to perform bonding every now and the.
