I2C driver problem?
I am using PCA10040 evaluation board to test I2C connection.
I tried twi_scanner sample code in SDK 12.
I wired SCL and SDA pins to D0 and D1 to a PicoScope device. image description
When the code was running, I captured signals from those two pins. image description image description
The clock and data lines are completely wrong, right?
  1. The clock cycles are far below expected: at least 8 for for one write, isn't it?
  2. Data line should start before clock line; but in my capture, they started to fall at almost the same time.
Can anyone explain why?
I also did another test with the following code:
int main(void) { nrf_gpio_cfg_output(ARDUINO_SCL_PIN); nrf_gpio_cfg_output(ARDUINO_SDA_PIN);
  for (address = 1; address <= TWI_ADDRESSES; address++)
	nrf_gpio_pin_set(ARDUINO_SDA_PIN);
	nrf_delay_ms(200);
	nrf_gpio_pin_set(ARDUINO_SCL_PIN);
	nrf_delay_ms(200);
	nrf_gpio_pin_clear(ARDUINO_SDA_PIN);
	nrf_delay_ms(200);
	nrf_gpio_pin_clear(ARDUINO_SCL_PIN);
	nrf_delay_ms(1000);
The captured two pins signals are as good as expected, which means my way of the signal monitoring is correct, unless for I2C wiring there are special settings I missed. image description
